boomer 30 electrical cluster
   / boomer 30 electrical cluster #1
kupperpooh
chilton
New Holland Boomer 30
Any ideas why my cluster would lock up. the rps, temperature and fuel guage don't move at all.
   / boomer 30 electrical cluster #2
If the fuse is good, check to see if they share a common ground wire.
The fuse controls the guages as well as the horn. The horn is working.
   / boomer 30 electrical cluster #4
But the horn probably has a separate ground. If you can find the ground for the instrument panel, try jumping the wire to a good ground and see if that helps.
   / boomer 30 electrical cluster #5
Did you find the source of the problem?
   / boomer 30 electrical cluster #6
UFO in the area...:eek:
So apparently it was a bad ignition switch? Does this even make sense?
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
2000 GMC C7500 CRANE TRUCK (A51406)
2000 GMC C7500...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
Simpson 3100 PSI Gas Pressure Washer (A51573)
Simpson 3100 PSI...
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
