boomer 30 electrical cluster
/ boomer 30 electrical cluster #1
kupperpooh
chilton
New Holland Boomer 30
Any ideas why my cluster would lock up. the rps, temperature and fuel guage don't move at all.
/ boomer 30 electrical cluster #2
If the fuse is good, check to see if they share a common ground wire.
The fuse controls the guages as well as the horn. The horn is working.
/ boomer 30 electrical cluster #4
But the horn probably has a separate ground. If you can find the ground for the instrument panel, try jumping the wire to a good ground and see if that helps.
/ boomer 30 electrical cluster #5
Did you find the source of the problem?
/ boomer 30 electrical cluster #6
UFO in the area...:eek:
So apparently it was a bad ignition switch? Does this even make sense?
2014 FREIGHTLINER CASCADIA T/A SLEEPER TRUCK TRACTOR (A59914)
2014 FREIGHTLINER...
2011 Dodge Charger (Police), VIN # 2B3CL3CG7BH526995 (A65563)
2011 Dodge Charger...
Bobcat 773 (A64126)
Bobcat 773 (A64126)
1999 GROVE MZ66DXT TELESCOPIC BOOM LIFT (A65053)
1999 GROVE MZ66DXT...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
John Deere 757 Zero Turn Mower (A66285)
John Deere 757...
