3-Point Hitch Boom pole lift expectations
   / Boom pole lift expectations #1
VroomVroom
Platinum Member
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
What weight have people lifted with their boom poles. I have a mahindra 2816, I was wondering what I could expect to lift with a boom pole. I know it would depend on the length of the boom pole, and of course safety. But generally what would one expect to lift with this. I wanted to build one to lift an engine out. What is the standard distance or length of a regular boom pole. Thanks.
   / Boom pole lift expectations #2
Depends on your tractor's 3pt lift capacity as well as your personal tolerance for failure relative to the task you are trying to do. How well built the implement is and how far back you hang the load (as you noted) will have a lot to do with your outcome. You have to make this assessment every time you use an implement based on the particulars of the job you are about to do.
I have easily lifted more than the 500# rating on my boom pole. Most recently I did so skidding out a 20' live maple trunk about 24" diameter at chest height. It was from a blowdown & I figure that was a good 3300# (assuming it would just barely float). Grabbed it at the butt end & lifted, so about 1600# on the tongs hung from the eye about 3 or 4' aft of the lower hitch pins. Probably not the smartest thing I have done, but a real motivation to weld up a proper 3pt skidder from a recently acquired HF quick hitch. This will allow me to do as I say & use the right tool for the job.
Be careful that you don't buckle it! Dropping a log in the woods is not the end of the world - dropping a good motor could be very damaging or dangerous, especially if you have helpers standing nearby.
-Jim
Yeah It would be. I could work it out I suppose as well. Normally when they rate the lifting capacity they are talking about pins, would that be the ball ends of the lift arms or where the actuators link onto the lower lift arms? If I knew which one they were talking about, I would work out the torque and then weight at various distances. Im not sure how heavy the engine is. I think the 3pt is rated at 2600 lbs on the 28hp tractor. Im just not sure at which point they are rating the lift. The engine would be a few hundred pounds no doubt. Flat head 6 dodge .
   / Boom pole lift expectations #4
I don't think you would have any problem lifting an engine with a boom pole...
I only have a small 17 HP b series and I move an old scrape blade around that weighs over 400#... can pick it up and load it on a trailer etc...
If your front wheels come off the ground...make sure you disconnected everything...:D
Hey pine, how long is your boom pole from the 3pt hitch on your tractor?
   / Boom pole lift expectations #6
Its a simple lever if you assume that the lower links and boom pole rotate at the same horizontal point. You know the lifting capcity at the pins is 2600lbs. So say your lower links are 3 feet long from pin to pivot point on the tractor. The availabe moment at the lower link pivot points (attached to the tractor) is 2600 lbs * 3 ft = 7800lb-ft. If your boom pole reaches 10 feet (horizontal distance) from the pivot point, that leaves you with 7800lb-ft / 10ft = 780 lbs. Variation in geometry through the 3ph may tweak this, but its a start for assuming the load capacity
   / Boom pole lift expectations #7
Here's a thread on my home-built boom pole:
http://www.tractorbynet.com/forums/build-yourself/151776-boom-pole-my-jd2520.html
The boom pole is 8 feet long and I think I maxed out at 641 lbs on the three-point with it, however, it is designed for 1000 + lbs. It has several lifting eyes, so could probably do more on the intermediate eyes.
If I remember correctly, I think I could barely lift 473 lbs or so with it mounted on the loader.
   / Boom pole lift expectations #8
Sorry I can't measure it but it's the typical 1000# capacity boom that TSC and others sell....I would guess it's about 7' ....no problem lifting loads from the bed of a pickup backed straight up, tailgate down...
...there is also a 500# capacity version available
   / Boom pole lift expectations #9
However, they do not - so it isnt a simple lever. The 3ph is a parallelogram linkage which, if perfect, would lift the boompole straight up without pivot/rotation. Such a condition would quarantee a very hi % of the lift at the eyes was available at any point on the boompole. Since it is not perfect you lose about 30% behind the eyes.
larry
   / Boom pole lift expectations #10
i have an old red TSC 'KK' boom pole. said it was the 500# model, though I have lifted an 800# disc from the end before. not that I advise that. but it has done it. normally for a heavy weight I'd use the mid point comnnection.
I have rigged it with a pulley and electric winch before too. nowadays a chain over the loader bucket does my lifting for me though with no wheelies :)
soundguy
2017 Bomag BMP 8500 Walk-Behind Articulated Tandem Compactor (A42742)
2017 Bomag BMP...
2001 Dodge Ram 2500 Pickup Truck Extended Cab (A44789)
2001 Dodge Ram...
Lely S/A Towable Broadcast Spreader (A42744)
Lely S/A Towable...
Chery 7' 16 Drawer Workbench (Blue) (A44502)
Chery 7' 16 Drawer...
1990 Ford Ranger 4x4 Pickup Truck, VIN # 1FTCR11TXLUC19238 (A44391)
1990 Ford Ranger...
Schulte CF05 Rotary Mower Deck (A44571)
Schulte CF05...
