Boom Pole For My JD2520
   / Boom Pole For My JD2520 #1
Runner
Elite Member
Missouri
2024 Cub Cadet Ultima ZTXS5 54, 2007 John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
Over the weekend, I made a boom pole for my JD2520. Since I previously made a three-point trailer hitch and quick hitch adapter for the loader, I decided to employ these elements in the boom pole. The other advantage to doing it this way is that the boom pole breaks down for easier transport/storage.
I used 1//4 inch thick walled 2x4 tubing for the main boom. I welded 3/8 inch by 4 inch wide plates on the sides to accept the top of the A-frame. On the business end, I used a piece of 1/2 inch thick by 3 inch wide bar stock.
The A-frame consists of 1 1/2 inch by 2 1/2 inch steel tube at the top, 1/4 inch walled 1 1/2 inch square tube for the legs and 1/2 inch thick by 3 inch wide bar stock for the bottom feet.
I load tested the boom at 641 lbs, which was the limit of what my machine could lift at the end of an 8 foot boom on the three-point hitch. The test weight was my weight box filled with a combination of concrete and four 42 lb JD suitcase weights.
Lastly, I decided to add a receiver hitch to the end, just in case.
   / Boom Pole For My JD2520 #5
very nice!. I bet the price of steel set you back some. at least you got a very useful boom out of it.
"I bet the price of steel set you back some. at least you got a very useful boom out of it."
It's a little hard to say exactly how much I have in it dollar-wise because one part (the trailer hitch) actually serves several purposes (trailer hitch, iMatch adapter and drawbar), so the cost of the steel/parts for that piece would have to be factored amongst the various uses. Also, some of the steel was scrap and stuff that was purchaced at other times and had pieces cut off for other purposes.
I figure I've got about $100 in the actual boom pole and the A-frame, so not too bad compared to a store-bought one.
A couple of mods already. I added a truss rod and a couple of lifting points to the bottom. Actually, I had already planned the truss rod, but thought I'd try it without just because it looked so good. However, I wanted to get rid of any deflection, so it got the truss rod after all.
Got it painted yesterday...
   / Boom Pole For My JD2520 #9
Nice work and very well built:D
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
CHICAGO MITER SAW (A58374)
CHICAGO MITER SAW...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
2016 Case CX55B Midi Excavator (A55973)
2016 Case CX55B...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
