Boom mounted mower
/ Boom mounted mower #1
breadtrk
Platinum Member
ashland city, tn
XR 3037 HST Cab
I want to build an attachment for my backhoe to replace the bucket with a regular riding mower deck. I can handle the fabrication aspect but I'm 100% in the dark on the hydraulics. The deck is your standard issue murray 2 spindle belt drive. I'm wondering if I should use 2 motors or one that drives the belt and then the spindles. I also have no idea of what size, flow, rpm's, etc would be needed for something like this. I have an LS XR3037 with rear remotes at about 8gpm. For now I'm thinking I'll just stick with the movement limits that a back hoe provides, I'm not wanting to rotate or tilt the deck beyond whatever movement a bucket would have.
/ Boom mounted mower #2
You don't specify pressure, but "assuming" it is around 2000 psi, 8 gpm gives you under 10 HP to drive the 2 blades. You are going to need more flow, IMO.
/ Boom mounted mower #3
Why not try out an arrangement which uses a gas motor to run a tow behind mower deck just to see if you really can or want to use something like this.
A gas motor isn't going to run at the angles this is going to be used at. I also want to keep the weight down as much as possible. Pressure is right at 2400lbs, the mower this 42" deck comes from had a 17hp engine and I imaging a significant amount of that power was used to propel the mower.
/ Boom mounted mower #5
Assuming 100% efficiency, that puts you at 11 hp. It actually takes less to propel than you may think.
Biggest power consumer on a rider is the deck
I really don't know,, and that is why I came to you guys. Lol
2022 RBR Venturi 430 High-Capacity Pneumatic Applicator (A63688)
2022 RBR Venturi...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
Generator (A61572)
Generator (A61572)
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
