bolts vs rivets for sickle mower
   / bolts vs rivets for sickle mower #1
jlbash1
Ohio County, Kentucky
Kubota L2650/Ford 3930
So I have never used bolts on a sickle mower, but think it would be nice. Do they make special bolts for this application? I would think they would have to be made of soft material so the bolts would give instead of breaking something else.
Thanks
Jarrod
Thanks
Jarrod
   / bolts vs rivets for sickle mower #3
The bolts are a bit special, they have a thickened portion where they go through the bar then thin again where the knife attaches.
BTW they are an absolute dream to use after rivits.
   / bolts vs rivets for sickle mower #4
   / bolts vs rivets for sickle mower #5
If you're not a regular sickle re-builder, rivets can drive you bonkers. But if you've done enough of them, they get easier with each re-sectioning.
I use an anvil to remove the old ones. (Put the bar against the top of the anvil with the section hanging down on the side. Smack the section with a HEAVY hammer. That shears the rivets. Use the same anvil and the same hammer to re-clinch the new rivets. With practice, a person can do a 7' bar in about an hour.
Bolts are easy. They are nice when you need to repace a section in the field too. But they AREN'T cheap compared to the rivets.
(I still prefer rivets.)
   / bolts vs rivets for sickle mower #6
   / bolts vs rivets for sickle mower #7
</font><font color="blue" class="small">( I would think they would have to be made of soft material so the bolts would give instead of breaking something else.
Thanks
Jarrod )</font>
Hi Jarrod,
Quite often sicklemowers have a ratcheting clutch assembly in case you run into something you shouldnt have /forums/images/graemlins/grin.gif
   / bolts vs rivets for sickle mower #8
Thanks
Jarrod )</font>
Hi Jarrod,
Doing an internet search for these hasn't yeilded much. Now of any good sources, or is this something I can pick up at any tractor dealer?
jarrod
jarrod
2001 Nissan Frontier Crew Cab Pickup Truck (A51692)
2001 Nissan...
Tallman Water Pump (A50774)
Tallman Water Pump...
IH 1066 Tractor (A50514)
IH 1066 Tractor...
Bale Ring (A50515)
Bale Ring (A50515)
We do NOT accept credit cards as payment. (A50120)
We do NOT accept...
