RalphVa
Super Member
- Joined
- Dec 19, 2003
- Messages
- 7,902
- Location
- Charlottesville, VA, USA
- Tractor
- JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I got the bolts off on my LX4 brush hog blades. Soaked them overnight with PB Blaster. One came loose with my Farmhand 1/2" drive impact wrench good for 550 ft lb. The other needed some help with a 6' pipe over the 3/4" driver.
Wonder how many times you can reuse these nuts? They're the type that are made to go and to come off tight, sorta like a huge Nyloc nut.
Sharpened both sides of the blades and actually went down the sharp edge and put a slight blunt edge on it. These things are really thick.
Think I'll just ratchet back my impact wrench a couple clicks to put the nuts back on and finish off by checking tightness with that 6' pipe cheater over the 3/4" drive. Wonder if anyone has used a spring scale on the end of a cheater bar to check torque. Seventy pounds at the end of 6' would be 420 ft lb. I don't have a spring scale so am inclined to just give it a snug pull on the end of that cheater bar.
The stump jumper on the LX4 is held on by both these bolts, too. Figured it was held in place by the center bolt.
Ralph
Ralph
