Bolt on tooth bar?
   / Bolt on tooth bar? #1
sarge rmb
Does anyone have a tooth bar for their Bx? Pics?:)
   / Bolt on tooth bar? #2
Many here at TBN have Markham Tooth-bars on their BX's... I've had one for a while and just got around to putting it one last month...
Just search Markham and you will see a lot of posts...
T Y very much!
   / Bolt on tooth bar? #4
I put a WR Long wear blade on mine. Either will fit nicely
   / Bolt on tooth bar? #5
I have a ATI it works great
The only thing I regret was I drilled my holes in the back of slot (told to do it by dealer)
and I cant flip it in to bucket sooner or later I weld it up and drill them in the front.
tommu
   / Bolt on tooth bar? #6
Pictures of Markham and others are on the Tooth Bar page of the BX Wiki
   / Bolt on tooth bar? #7
I have a Markham and couldn't be more pleased with the order process, prompt delivery and bar itself.
regards,
Steve
   / Bolt on tooth bar? #8
regards,
Steve
I will second RBCSAVER. Markham is top notch!
   / Bolt on tooth bar? #9
Markham is very popular here, but I still tout the WR Long FTB. Not because it's better quality than the others - can't speak to that - but because it's "flat". Back dragging with the bucket leaves a smooth finish - no grooves from the teeth - and the flat bar being under the bucket
Tooth Bars TB, STB, and ITB
I abuse mine and it has stood up fine. Based on posts here quality seems at least equal to the other brands.
Only potential downside is that you can't order direct - need to see your dealer...
   / Bolt on tooth bar? #10
i just put a wr long bar get a flat tooth bar it better they are level with bucket they are not below bucket
18 Front Suitcase Weights with Brackets (A53472)
18 Front Suitcase...
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A53117)
2025 K0311 UNUSED...
Toro Mower (A50324)
Toro Mower (A50324)
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
