Bolt on tooth bar?
   / Bolt on tooth bar? #1
sarge rmb
Does anyone have a tooth bar for their Bx? Pics?:)
   / Bolt on tooth bar? #2
Many here at TBN have Markham Tooth-bars on their BX's... I've had one for a while and just got around to putting it one last month...
Just search Markham and you will see a lot of posts...
T Y very much!
   / Bolt on tooth bar? #4
I put a WR Long wear blade on mine. Either will fit nicely
   / Bolt on tooth bar? #5
I have a ATI it works great
The only thing I regret was I drilled my holes in the back of slot (told to do it by dealer)
and I cant flip it in to bucket sooner or later I weld it up and drill them in the front.
tommu
   / Bolt on tooth bar? #6
Pictures of Markham and others are on the Tooth Bar page of the BX Wiki
   / Bolt on tooth bar? #7
I have a Markham and couldn't be more pleased with the order process, prompt delivery and bar itself.
regards,
Steve
   / Bolt on tooth bar? #8
regards,
Steve
I will second RBCSAVER. Markham is top notch!
   / Bolt on tooth bar? #9
Markham is very popular here, but I still tout the WR Long FTB. Not because it's better quality than the others - can't speak to that - but because it's "flat". Back dragging with the bucket leaves a smooth finish - no grooves from the teeth - and the flat bar being under the bucket
Tooth Bars TB, STB, and ITB
I abuse mine and it has stood up fine. Based on posts here quality seems at least equal to the other brands.
Only potential downside is that you can't order direct - need to see your dealer...
   / Bolt on tooth bar? #10
i just put a wr long bar get a flat tooth bar it better they are level with bucket they are not below bucket
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
UNUSED WOLVERINE GB-11-72W-72" HYD GRAPPLE BUCKET (A51248)
UNUSED WOLVERINE...
2020 RoGator RG1300 Air Max Precision R2 Spreader (A53342)
2020 RoGator...
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
2517 (A51248)
2517 (A51248)
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
