Bolt holes on B3200 differntial
   / Bolt holes on B3200 differntial #1
ruralruss
NW Georgia
Kubota B3200
Does anybody know what these four 12 mm bolt holes on each side of differential are for?
Cheers
   / Bolt holes on B3200 differntial #2
I'll say good question! They are on most B-series tractors and they might be used with different applications in other countrys.
   / Bolt holes on B3200 differntial #3
Does anybody know what these four 12 mm bolt holes on each side of differential are for? Cheers
Are you talking on the end of the differential, if so they are bolt holes for the sub frame to bolt to for the backhoe.
I don't know what good they are (for strength) because when I got my B3200 TLB one of the holes had been stripped out by the mechanic that installed the sub frame not using a torque wrench and just cranking on it.
It is just soft cast iron and easily stripped. Luckily I measured the depth of the hole and there were some deeper threads left so I got a longer bolt and used some Locktite on it. I didn't put a lot of torque on it but it snugged up and has held so far.
I can't see what strength these gives to the sub frame as there are so many other huge bolts holding it in place these seem like they are of no use at all, especially with the short and skimpy bolts used at this location.
If you aren't talking about these holes I don't know which you are talking about. Hope this helps.
I am talking about the 4 holes on each side of the differential. They take a 12mm bolt and go about 25 to 30 mm deep. They are in a square pattern around the axle.
Cheers
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
(INOP) CATERPILLAR 314 EXCAVATOR (A51243)
(INOP) CATERPILLAR...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
RURAL KING RK37 TRACTOR (A51243)
RURAL KING RK37...
2016 Ford Taurus AWD Sedan (A50324)
2016 Ford Taurus...
