Bolt holes on axle housing
   / Bolt holes on axle housing #1
Pks
Platinum Member
Saline, Michigan
Kubota L3700SU, Cub Cadet 1430, Hustler Super-Z 66in, Vermeer 1250
On the B2400, I have noticed four bolt holes on each of the rear axle housings. These bolt holes form a square pattern, surrounding the axle, when viewed from the end of the axle.
On older model tractors, NAA, 8N etc. these holes exist for the purpose of attaching chains or bars to help stabilize the 3 pt mount.
In the case of the B series, what are these used for, backhoe subframe?
Do all the B models have these bolt holes?
   / Bolt holes on axle housing #2
My 2710 has them also, as does the 2910. On mine I have used them for the Backhoe subframe mounting weldments. I like the Bush hog backhoe design because it hangs the subframe off the axle and not in the lower 3pt link pins....
   / Bolt holes on axle housing #3
They are there on my B7500 too. Not in a square pattern though; a rectangle, longer front to back than up and down. Kind of makes a guy want to find something to bolt on in there...
Yeah, I know exactly what you mean.
If my wife were reading this, she might say something about that too. /forums/images/graemlins/grin.gif /forums/images/graemlins/tongue.gif
Uh, back to the regularly scheduled programm...
Hearing the bolt holes are used by subframes tells me they have lots of strength.
Nice to know if I ever have a use for them.
Thanks for the info.
2004 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2004 CATERPILLAR...
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2012 FRAC TANK (A53843)
2012 FRAC TANK...
