Bolt for tapered pin?
/ Bolt for tapered pin? #1
KnuckleDragger
Bronze Member
The Heartland of America
After overhauling the slip clutches on my bat wing mower, I was unable to salvage one of the threaded tapered pins that attaches the wing driveshaft to the center gearbox. Replacements are in the neighborhood of $28. Can I get by with a standard bolt for a mowing session or two?
/ Bolt for tapered pin? #2
Hello as for your question {you can if you want to} but replacing the drive shat and or yolk will cost more than the $28 pin. If I recall the pin is tapered to only go in one way, it pulls every thing tight together. If you think a bolt will hold it tight give it a try but check it after the first or second mowing.
Best of luck.http://www.tractorbynet.com/forums/images/smilies/biggrin.gif
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
2011 Ford F-250 RKI Service Truck (A61573)
2011 Ford F-250...
Hurricane Power X3 Walk-Behind Debris Blower (A61572)
Hurricane Power X3...
1067 (A63291)
1067 (A63291)
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
iDrive TDS-2010H...
