Mowing Bolens model 1349 belly mower mounting
   / Bolens model 1349 belly mower mounting #1
dbfoley
Clifton Springs, NY
Bolens G154
I have a Bolens model 1349 48 inch belly mower on my Bolens G154 tractor. I think the linkage to the three point hitch is installed wrong but I cannot find a diagram showing how it should be mounted. If you look at the photos you will see the lift cables that connect to the three point hitch are rubbing up against the rear transmission housing. I do not think that this was the way it was designed. I have the mower parts manual (4 page) and Tractor owners guide (24page) but neither shows how this belly mower should be mounted. Can anyone help or does someone have a manual that shows how this mower should be attached.
Is there a manual that shows the attachments and how to use them
Thanks
Dfoley
   / Bolens model 1349 belly mower mounting #2
With a little effort ,to those drop straps ,where the cables attach ,you can fix your problem.. They should be more down than curved in ,yours have been bent in for some reason,. just put some force to them and they will yield to the pressure and you will have the result you are desiring. Hope this helps
   / Bolens model 1349 belly mower mounting #3
hope this actually appears
2011 GMC Acadia SLE SUV (A53424)
2011 GMC Acadia...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
78'' skeleton /rock bucket (A53421)
78'' skeleton...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2016 Utility 102"x48' Flatbed Trailer (A50123)
2016 Utility...
