Bolens/Iseki rototiller help needed
   / Bolens/Iseki rototiller help needed
Well... I called around and the word is, Nope! We ain't takin those piece of junk on trade 'cause no-one want 'em. You'd get more fer it as scrap metal than as a tiller"
I looked the tiller over. The bearings are tight, but the tines are worn. After checking things out and doing a bit of thinking and looking, I got thinking it could be converted into a rotisserie! /forums/images/graemlins/laugh.gif The low range that my PTO on my tractor turns @ 2400 rpm is 450RPM. I think I can get the gear ratio to turn just right to cook a wiener pig or a leg of cow. /forums/images/graemlins/laugh.gif You know guys and gals, it's BBQ time coming up quick! (If yer from Texas, it's ALWAYS BBQ time!
   / Bolens/Iseki rototiller help needed #12
I've got an Iseki 3 point tiller for my TL2100. The driveline is so short it blows the universal joints when you lift it while it's spinning. I've got to extend the hitch and lengthen the driveline apparently. Keep an eye on eBay as I've seen tines there that fit mine at least.
   / Bolens/Iseki rototiller help needed #13
This is a picture of my tiller showing one mounting pin in place and I have noted the lifting arms mounting pin locations.
The PTO drive shaft is shown just for good measure it's 280mm long.
Hope this helps. /forums/images/graemlins/smile.gif
I have a ts 1910 iseki with a [I assume] iseki rototiller The pto connection was lost it is as yours pictured Where can I get one? Towny , Wangaratta AUS
LOT OF TIN (A58374)
LOT OF TIN (A58374)
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
(2) POLY ANTI-SPILL CONTAINERS (A52708)
(2) POLY...
2834 (A58376)
2834 (A58376)
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
8 sets of Jumper Cables (New/Unused) (A59225)
8 sets of Jumper...
