Rod in Forfar
Platinum Member
- Joined
 - Apr 10, 2010
- Messages
 - 582
- Location
 - Forfar, Ontario, Canada
- Tractor
 - 1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
The tractor is a 4WD, 17 hp Iseki/Bolens, 1981.
The problem seems cold-related, and bearing-related, insofar as it only zings when the clutch is out. Otherwise I'd say it's from the hydraulic pump, as that's where the sounds seems to originate. Seeking water in the fluid I drained the tranny only to find it was pretty good. No luck there. Is there an area in the front end prone to icing I should drain and refill?
Thanks,
Rod
Thanks,
Rod
