Bolens G152 Hydraulics
   / Bolens G152 Hydraulics #1
opsret2010
bolens g152
Hello, I am a new member and owner of a Bolens G152 compact tractor and have owned it since new in 1988. I would like to put a hydraulic snow plow on the front but don't know how to tap into the tractors rear 3 pt hitch hydraulics. Does anyone have ideas?
   / Bolens G152 Hydraulics #2
Ampa on the Iseki site has just done this on his Bolens G174. He has illustrated his work well with photos, and would likely be happy to tell you which parts to buy.
   / Bolens G152 Hydraulics #3
That part of it was easy....cut the exsisting presure line allow for compression fittings....get these at any hydraulic supply....I bought an 4' ATV plough you can buy a 60" 5'....
uses an "A" frame which is extra....this unit comes as a manual lift.don't need the manual bar lever..I converted mine ove to hydraulic....the "A" frame connects under the tractor...you need to make up the side brackets....unless you can get the old belly mower brackets from someone...
I used a 4" stroke DA cylinder/ram for the lift....and a 8" DA cylinder/ram for the angle....then you will need a double valve....there are a ton of fittings to buy...then your hoses to be made up...expect to pay around $1500.00 cdn for everything not including your time if your live in Canada..much cheaper in the USA...it's a fun project...mine works excellent....and your 3 PT hydraulics will still work as before...go for it....Welcome to TBN....take care Ampa <>
   / Bolens G152 Hydraulics #4
Click on "ampa"s name. It will show a page on him, then click "statistics", then click on "threads" started by ampa,you will find a pretty good detail to the work he did. And a good job at that.:)
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A49461)
2007 Reitnouer 40...
2012 GROVE TMS900E TRUCK CRANE (A50854)
2012 GROVE TMS900E...
2014 TOP HAT TRAILER MFG. LIGHT PLANT TRAILER (A50854)
2014 TOP HAT...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52128)
Mitsubishi FG35...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
