Boiling hot rad hose heater
   / Boiling hot rad hose heater #1
1981
Arrow creek, bc
Massey ferguson 210-4
Installed a zerostart 1 1/2" lower rad hose heater 600 watt on my 1981 Massey Ferguson 210-4.
It gets very hot in about 10 minutes. In an hour I can feel heat in top hose, top of rad and a little on top of block.
It is getting so hot I can hear the antifreeze boiling just above the heater, is this normal ?
The heater has a thermastat, but after 2 hrs, I have not noticed it cutting out.
Is the boiling antifreeze a problem ?
Thanks for any help
Randy
   / Boiling hot rad hose heater #2
You put a heater in the cooling system. IT's supposed to heat the water.
You may have a circulation issue if you want just a "gentle heating". The thermostat won't open until what, 220 f? You can work on that.
My choice would be to start the heating process in a time sufficient to get the engine started, and no more. Say 20 min or so.
   / Boiling hot rad hose heater #3
I agree, with the timed useage. Put it on a heavy duty timer where it turns on at a certain time and goes off 20 min later. Boiling coolant is not a good thing- it will make it sludge then jam your radiator/cooling system.
   / Boiling hot rad hose heater #4
Put it on a timer, maybe 20 minutes maximum.
I had one of those bottom hose heaters in our 220D Mercedes. Put it on about 30 minutes before starting it in -22 F weather. Engine fired right up.
Ralph
   / Boiling hot rad hose heater #5
Thanks for any help
Randy
Yes, it's normal and no, it's not a problem. Millions of coolant heaters do exactly the same thing. What you are hearing is the boiling of the coolant that is touching the heating element. It's all a matter of how much energy you are trying to get into the coolant in X amount of time. If you had a heater that didn't make an audible noise when operating it's likely it would take a very long time to warm the coolant and it possible might not even keep up to the heat loss as the coolant circulates.
Here's a couple of nice little charts.
Thanks for the advice, I will keep my plug in time down to about 30 minutes. No need for a timer as I am retired:drink: and the tractors main use is for running pto chipper and some snow plowing with rear blade, and I can do both on my own schedule. By the time I get my gear ready and do a walk around checking for leaks and things, it should be good to go.image.jpgimage.jpg
Heater pic is upside down
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A58018)
2017 UTILITY VS2RA...
2015 Ford F-550 Crew Cab ETI ETC35SNT 35ft Bucket Truck (A55973)
2015 Ford F-550...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
