Bobocat CT 335 electrical no start
   / Bobocat CT 335 electrical no start #1
Dustin Winick
2015 Bobcat ct 335
My CT335 for the longest time always acted like the battery didnt have enough juice when starting, turns out it was the ground so i replaced it and everything worked fine. A few months later now and the engine will not turn over with the key, I can open the hood and jump the starter solenoid and it will fire right up. Also when the no start issue started i noticed my glow plugs dont work when i turn the key forward, I have to manually turn the key backwards and hold it to make them work. My cruise control quit at the same time also. The only safety switch that has been bypassed is the seat switch because my son was to light and when he was mowing the fields he would bounce up and the tractor would stop. Not quite sure where to start looking at this point. I was also thinking that when the tractor was new there was a light on the dash to tell you what gear the trans was in and i dont see that any more
   / Bobocat CT 335 electrical no start #2
You might have already pointed to the key of the switch problem
   / Bobocat CT 335 electrical no start #3
Yep, key switch sounds like the problem. I would pull it out and test continuity of the contacts at each position with a voltmeter & wiring diagram
2017 Ram 5500 Chassis Crew Cab Reading Service Truck (A52377)
2017 Ram 5500...
2019 TOP HAT TRAILER 20 FOOT UTILITY TRAILER (A53843)
2019 TOP HAT...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2012 BIG TEX UTILITY TRAILER (A53843)
2012 BIG TEX...
