Buying Advice Bobcat Toolcat- Is it the right tractor for my Facility
   / Bobcat Toolcat- Is it the right tractor for my Facility #71
Had a Tool Cat on trial for a week. It is the MOST FRUSTRATING piece of equipment I have ever used! The Arms on the 3Point Hitch are not extensible which, if you could see the equipment you were attaching to, would not be a problem. But you can't. So you do a lot of getting in and out of the cab as you line up with the equipment. This highlights to other problems. The vehicle will not move unless the door is closed and (if you can believe it) the outboard arm rest is down! Infuriating! It seems like a great idea. 60hp, steering both front and rear, PTO and 3PH on the back and a bobcat attachment and third function hydraulics on the front, all with a heated and air conditioned cab. The reality however is a $60K ergonomic nightmare that would need significant user modifications to make it serviceable.
You are the only one that I remember complaining about this.
The F Series we had and the G Series we have would both move with the door open, as long as the safety arm rest is down.
I have stood outside with the arm down and used the joystick to move the boom or curl the forks. Didn't try to move the machine though.
I don't have any problems hooking up the three point hitch, just roll the stuff into position:
   / Bobcat Toolcat- Is it the right tractor for my Facility #72
I have the R4 tires and wish I had turf for snow.. this is the 3rd year with the SB200 blower on the front.. first year put 3 35 gallon drums full of sand and rock in the box for traction, limited success then added chains to rear tires.. second year same but added front chains. this year I'm going to start with just chains all around and skip the weight if I can.. the blower is pretty heavy so was hoping the weight in the back would offset it but hate having the drums back there all winter much less the loading and unloading..
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A56435)
2017 Cadillac...
2012 Bigtex Trailer (A55973)
2012 Bigtex...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
44052 (A55852)
44052 (A55852)
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
