Bobcat t650 brake issue
   / Bobcat t650 brake issue #1
catdozer
Platinum Member
john deere
I have 2 2014 650 bobcats, 1 is millionth edition t650 and a s650. Both are completely identical with 1000hrs on each. The track machine has been giving us issues with the right side track motor. Has a squeal like the brake dragging. Took motor off and bobcat tore it down and said it's fine. So traced it to the valve block for brakes and 2 speed and said that was the issue. Replaced it with a full assembly. And still getting the squeal sometimes. But after running it a bit it goes away or sometimes it never squeals at all. Charge pressure is 438 on both machines. Any help with this? 20180726_134711.jpeg1532628319750.jpeg1532628351315.jpeg
Well I got some help from another dealer that knew about bobcats better than anyone I ever talked to. Little fitting on the backside of the pump with this spring and ball. The screen becomes inverted and becomes like a plug. Reads pressure just fine but doesn't quite have the flow. 8$ part #7202329. This is after I spent 2k with our local dealer that couldn't figure it out. 1532633133283.jpeg
   / Bobcat t650 brake issue #3
Hi im having a similar issue with my 2014 T650. could you give mea little more info on where to get this spring? or maybe a contact number to the dealer you talked to? thanks
   / Bobcat t650 brake issue #4
Its nice when it works out good.
   / Bobcat t650 brake issue #5
Thank you for sharing this made it a quick fix for me on our T770. Changed out the oring to JIC fitting off the valve block and problems went away. Here is a diagram where to find it. It’s on the back of the valve block towards the motor with a small steel line going to it. Number 43 on the diagram.
   / Bobcat t650 brake issue #6
Thank you so much for posting this! It fixed my neighbors t650 in short order!
Pallet of Gas Powered Misc Engines (A54865)
Pallet of Gas...
(4) New Winch Straps (A54865)
(4) New Winch...
2012 CM  T/A ENCLOSED 14 TRAILER (A55745)
2012 CM T/A...
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
MISC LOT (A55745)
MISC LOT (A55745)
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
