Bobcat T300 stalls under load and hyd. fluid seems to heat up fast.
   / Bobcat T300 stalls under load and hyd. fluid seems to heat up fast. #1
ronniebrugh
Louisville, Kentucky
Bobcat t300
2005 T300 new hydrostatic and gear pump, drive motors, hoses, case drain and hyd. filters, flushed oil cooler, new brake valve assy., new main relief valve, charge pressure good...
if you move either stick or both forward it stalls out.... and fluid seems really hot... thinking flow restriction somewhere?
   / Bobcat T300 stalls under load and hyd. fluid seems to heat up fast. #2
Does the lift and tilt function normally? Perhaps the aux circuit is on and deadheading. Don't know if the track machines have the solenoid brake, but that will stall a wheeled machine when they won't disengage.
lift and tilt work fine and tracks work until steering lever are past half way... if you push or pull steering lever to full on machine will stall out...
   / Bobcat T300 stalls under load and hyd. fluid seems to heat up fast. #4
You might post over on The Skidsteer Forum, there are some pretty sharp guys that work on things, and a few recent T300 posts.
thanks i tried the skidsteer forum but cant get a reply to open account
MONOSEM NG-3 LOT NUMBER 273 (A53084)
MONOSEM NG-3 LOT...
1999 KENWORTH T800 DAY CAB (A53426)
1999 KENWORTH T800...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2020 CASE IH 110N LOT NUMBER 222 (A53084)
2020 CASE IH 110N...
