Bobcat T300 stalls under load and hyd. fluid seems to heat up fast.
   / Bobcat T300 stalls under load and hyd. fluid seems to heat up fast. #1
ronniebrugh
Louisville, Kentucky
Bobcat t300
2005 T300 new hydrostatic and gear pump, drive motors, hoses, case drain and hyd. filters, flushed oil cooler, new brake valve assy., new main relief valve, charge pressure good...
if you move either stick or both forward it stalls out.... and fluid seems really hot... thinking flow restriction somewhere?
   / Bobcat T300 stalls under load and hyd. fluid seems to heat up fast. #2
Does the lift and tilt function normally? Perhaps the aux circuit is on and deadheading. Don't know if the track machines have the solenoid brake, but that will stall a wheeled machine when they won't disengage.
lift and tilt work fine and tracks work until steering lever are past half way... if you push or pull steering lever to full on machine will stall out...
   / Bobcat T300 stalls under load and hyd. fluid seems to heat up fast. #4
You might post over on The Skidsteer Forum, there are some pretty sharp guys that work on things, and a few recent T300 posts.
thanks i tried the skidsteer forum but cant get a reply to open account
66 Tomahawk Skid Steer Bucket (A52384)
66 Tomahawk Skid...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
New/Unused 2025 CFG MX20R Mini Excavator (A51573)
New/Unused 2025...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
