Bobcat T190 with Kabota motor low oil pressure
   / Bobcat T190 with Kabota motor low oil pressure #1
67GTXman
Versailles, Mo
Bobcat T-190
I have a T-190 that I got stuck in the mud and was almost standing straight up with the motor running for about 15 minutes and then the motor shut off. Once I got it pulled out it started but the oil pressure went to 0 after running for only a few minutes. I have replaced the bearings, oil pump and cleaned everything out , I installed a manual oil pressure gauge to bypass the oil sending unit and now after running the oil pressure goes down to almost nothing once the machine heats up. Any suggestions. I don't want to have to replace the motor but it looking like that may be my next step.
   / Bobcat T190 with Kabota motor low oil pressure #2
Did you replace the cam bearings as well ? Cam bearings dont normally knock or tick when worn and the first symptom is usually low oil pressure because the clearances have grown too large.
Ray
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
2013 ISUZU NPR STAKE BODY TRUCK (A54313)
2013 ISUZU NPR...
2005 CATERPILLAR 740 - 6X6 OFF ROAD WATER TRUCK (A52706)
2005 CATERPILLAR...
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
28013 (A50322)
28013 (A50322)
