Bobcat T190 with Kabota motor low oil pressure
   / Bobcat T190 with Kabota motor low oil pressure #1
67GTXman
Versailles, Mo
Bobcat T-190
I have a T-190 that I got stuck in the mud and was almost standing straight up with the motor running for about 15 minutes and then the motor shut off. Once I got it pulled out it started but the oil pressure went to 0 after running for only a few minutes. I have replaced the bearings, oil pump and cleaned everything out , I installed a manual oil pressure gauge to bypass the oil sending unit and now after running the oil pressure goes down to almost nothing once the machine heats up. Any suggestions. I don't want to have to replace the motor but it looking like that may be my next step.
   / Bobcat T190 with Kabota motor low oil pressure #2
Did you replace the cam bearings as well ? Cam bearings dont normally knock or tick when worn and the first symptom is usually low oil pressure because the clearances have grown too large.
Ray
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A52377)
2019 Allmand...
2006 BOBCAT ZHS 435 FAST TRACK EXCAVATOR (A52705)
2006 BOBCAT ZHS...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
Adams 6 Ton Hydraulic Lime Spreader (A55301)
Adams 6 Ton...
2007 Volvo VNL Truck Tractor (A55218)
2007 Volvo VNL...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
