bobcat s590 setting default speed
/ bobcat s590 setting default speed #1
laurencen
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
need help setting the default speed on a 2015 S590, I can turn on 2 speed with the button on the left joystick, it defaults to 50%, this can be increased to 99% with the up/down control, the issue is when the unit is turned off it goes back to default 50%, anyone know how to set default to the 99% when the key is turned
thanks
/ bobcat s590 setting default speed #2
Make the adjustment as you have, and the. Hold down the button with the snail on it on the left joystick until you hear a beep. The default setting should now be changed.
thanks, I will try that tonight
well tried it and works great, funny my dealer had no idea how to do this other than going thro the controller and programming it, betting there are other shortcuts
like this one
Thanks DJGTWO
/ bobcat s590 setting default speed #5
Glad to hear it worked for you. Most default settings on Bobcat have easy ways to change them.
2017 TROXELL 130 BBL VACUUM TRAILER (A63569)
2017 TROXELL 130...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
Mini Skid Steer (A60352)
Mini Skid Steer...
(2) GAS POWERED BLOWERS (A63745)
(2) GAS POWERED...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
John Deere 1023E (A62177)
John Deere 1023E...
