Bobcat S590 auxiliary hydro speed
   / Bobcat S590 auxiliary hydro speed #1
laurencen
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
for my S590 the auxiliary hydraulic in standard is too high for the snow dump bucket, yes the thumb switch can vary the speed but its getting a pain having the dump slam back to the arms, is there a simple way to reduce this speed say 25% without adding a restrictor to the lines
   / Bobcat S590 auxiliary hydro speed #2
What is the problem with adding a restrictor? That is by far your easiest option. Just one more fitting between hose and cylinder.
im using a dump bucket for snow, when activating the auxiliary to dump the 1 1/2 cylinders move the bucket quite fast, worse when returning the bucket, slowing it down would make it more comfortable and less hammering on the machine
figured restrictor would put continuous load on the lines, have to give it a try next couple days and see how it works
   / Bobcat S590 auxiliary hydro speed #4
Let us know what you find. I believe you will be happy after some fiddling around.
   / Bobcat S590 auxiliary hydro speed #5
One fixed restrictor/orifice in one line is all that is needed to slow speed in both directions. This is fairly common practice when slowing cylinder movement is desired. In fact Bobcat offers a restrictor for some of the industrial grapples for customers that require more precision control.
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A51222)
2020 INTERNATIONAL...
2012 International Day Cab Truck Tractor (A50323)
2012 International...
Horst Quick Tach Bucket (A52349)
Horst Quick Tach...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A52128)
2021 John Deere...
2013 John Deere 160G LC Excavator (RIDE AND DRIVE) (A50774)
2013 John Deere...
Case IH Farmall 75C (A52349)
Case IH Farmall...
