bobcat s250 acs code32-39
   / bobcat s250 acs code32-39 #1
fishcman
utah
none ranger boat lol
how can i adjust acs to neutral????????????
   / bobcat s250 acs code32-39 #2
keep your hands off them when you start the machine. If one is not sitting in neutral, you will throw a code. Could be a bad controller.. maybe Doxie will weigh in on this.
   / bobcat s250 acs code32-39 #3
:welcome:
To the forum from Alabama.
   / bobcat s250 acs code32-39 #4
To list some things that can cause this:
1. Inadvertnally moving a control while reaching to push the PTO button.
2. Weak springs in control, not bringing it back clsoe to center.
3. Actuator getting worn, not returning to neutral or sensor in actuator worn and not sending correct feedback signal.
4. Control valve spool or the valve centering spring binding not allowing it to center.
Try starting without hands on the controls. If problem still happens, with key off jiggle the controls trying to feel for most neutral spot then re-try starting without touching controls.
If either of these don't work, the best bet is have a dealer hook up his laptop to read the system to see what is going on.
ok i will try that thank you very much.
   / bobcat s250 acs code32-39 #6
32-39 ACS lift actuator is not in the neutral position
FAE 150/540 LOT IDENTIFIER 124 (A53084)
FAE 150/540 LOT...
2020 JOHN DEERE 7R210 LOT IDENTIFIER 253 (A53084)
2020 JOHN DEERE...
UNUSED FUTURE PC711 - 71" HYD PLATE COMPACTOR (A51248)
UNUSED FUTURE...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
2023 JOHN DEERE 7R210 LOT IDENTIFIER 88 (A53084)
2023 JOHN DEERE...
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
