Bobcat M700 problems
   / Bobcat M700 problems #1
djw250
Hurricane alley (South Louisiana)
Mahindra 3510
I recently acquired a Melroe Bobcat M700 circa 1974. It runs good, but has problems with the drive. When you first crank it up, it drives and turns pretty good, but after about 5 minutes, the drive gets noisy, jerky, and almost quits completely. If you let it sit for a few minutes, it will go again, but doesn't last long. The lift still works pretty good, and the hydraulic fluid is not hot. It seems like it isn't getting fluid to the drive motors. I'm also not sure how to check the fluid level. There are two 1/2" plugs on the left side between the wheels, one about an inch lower than the other. Could this be the upper and lower level for the fluid? I have been around tractors all my life, but I know nothing about skid steers so any help would be greatly appreciated.
   / Bobcat M700 problems #2
There is a filter under the machine that needs changing. It holds 20 Gallons of Hydro. fluid. Remove the Larger of the two plugs on the left side, if fluid comes out, the fluid is ok, if it doesn"t ,replace plug and remove the small plug and add fluid until it runs out. open back door and the fill tube is on the left side
1997 National RV Tropi-Cal Motorhome (A51694)
1997 National RV...
WESSEX CRX 240 LOT IDENTIFIER 265 (A53084)
WESSEX CRX 240 LOT...
(8) DRAWER METAL TOOLBOX (A51248)
(8) DRAWER METAL...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
UNUSED MOWER KING ECSSTR072-72" HYD TILLER (A51248)
UNUSED MOWER KING...
2012 Honda Pilot SUV (A51694)
2012 Honda Pilot...
