bobcat lost all hydraulics on 331 mini excavator
   / bobcat lost all hydraulics on 331 mini excavator #11
it starts but doesnt do anything after the safety lever is engaged? have you checked the switch just under the lever? can jump the wires to check.
   / bobcat lost all hydraulics on 331 mini excavator #12
I'm having the same issues I have a 01 bobcat 331 d series I have no controls forward reverse blade controls when I put the armrest down the light comes on but nothing works any help
   / bobcat lost all hydraulics on 331 mini excavator #13
Did you ever get this figured out? Ive got a 331d, pump coupler is good, replaced console switch and didn't fix it. Its got fluid, all fuses are good, hydraulic light comes on when left console is engauged, no blade or travel. Machine is sitting in the middle of my back yard lol.
   / bobcat lost all hydraulics on 331 mini excavator #14
Possibility that the pump gear has loosened on shaft and moved forward so teeth are only engaging a portion of the nylon tooth width.
What is the serial number of this 331? The 331 covered several years of production had several design changes during production. One of major changes was introduced when 331D came out, the D series and later use a variable displacement, load sense pump. Earlier versions had 3 section gear pump. All versions used mechanical linkage on blade control, meaning that the are rest switch did not affect this function so diagnose problem using the blade function.
Now if it is a D series or later, has piston pump, and drive coupler is fine and no blade function, that narrows it down to problem in load sense circuit. When engine running with all functions in neutral position the pump is at minimal stoke moving just enough fluid to maintain the pilot pressure at the joystick. When any valve is activated the change is pressure and flow is sensed through the load sense line from valve to pump allowing the pump to move to on stoke sending fluid to the function.
Summary: If all functions are inop including blade and machine has a gear pump only commonality to all functions is the coupler. If it has the the piston pump the pump coupler or load sense circuit could be the issue.
Where would i be able to troubleshoot the load sense circuit?
   / bobcat lost all hydraulics on 331 mini excavator #15
Did you ever get your 331 fixed? I've got one with same problem.
   / bobcat lost all hydraulics on 331 mini excavator #16
Did you ever get your 331 fixed? I've got the same problem with mine.
2019 Chevrolet Cruze Sedan (A55758)
2019 Chevrolet...
2001 International 4700 Dump Truck, VIN # 1HTSCAAM51H379512 (A54865)
2001 International...
UNDERCARRIAGE ROLLERS (A53843)
UNDERCARRIAGE...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A55301)
Gooseneck...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55302)
2012 UNVERFERTH...
