Bobcat has no lift power
   / Bobcat has no lift power #1
jena
phelan, ca
bobcat 753
I have a bobcat I can tilt the bucket but no lift power. After warming up sometimes I can get the bucket to lift but not all the time. I have checked for leaks found none. Would just like to be pointed in the right direction please Any replies will be greatly appreciated
   / Bobcat has no lift power #2
Put a hyd gage in the lift circuit and see what the pressure is.
When you move the spool, fluid is supposed to go somewhere, either the spool is not moving, or the fluid is sent somewhere else.
The shaft nut holding the piston on in the cyl could have come off, and the fluid is recirculating.
   / Bobcat has no lift power #3
One of the lift cylinders has failed (blown seals, piston nut loose or broken hyd rod internally)
   / Bobcat has no lift power #4
You probably have a bad disconnect. Internal failure is common. I have had several go bad and keep spares on hand.
You say your bucket curl works, so to check swap the hoses under the unit and try the lift. if the lift works you know the disconnect on the hose end is bad. The second check is to swap the end of the hoses where they connect to the cylinders. Be sure you depressurize before removing (with unit off move lever around through all positions).
Hope this helps.
PS be sure you note the brand and number of the disconnect when getting replacements. They are not generic.
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
2019 Isuzu NPR-HD 24ft. Box Truck (A55788)
2019 Isuzu NPR-HD...
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
