Bobcat e35 exc
/ Bobcat e35 exc #1
MX195
Weare, NH
Kubota L4600
Can anybody help me with this one? I've been a heavy equipment tech for 30 yrs. I rented a Bobcat e35 mini exc for the long weekend here for property improvements. Machine is BRAND NEW. Only had .8 hrs on it when I picked it up. Machine worked fine for one day. The 2nd day it "lost" all of it's tractive power. It will only travel in a straight line forward and reverse and will not climb a hill steeper than about 5 degrees. Unit will not turn unless you happen to be on a slope and activate a downhill motion turn. You can hear the hydraulic oil bypassing the relief valve what seems like all the time while trying to travel and turn. Also, when I was at the dealer picking it up, one of their techs was working on a similar machine. He had the whole machine off the ground using the boom on one end and the grader blade on the other. This machine will not do that. Just doesn't seem to have the chowder. Is there a quick setting I can change or something similar so I can use this **** thing? It's a rental so I don't want to break out the gauges and start messing around with relief pressures etc........
/ Bobcat e35 exc #2
That is a load sense/supply on demand pump. Either something is obsrtucing the load sense circuit or an oring seal is leaking at the main releif valve. This something the dealer needs to look at.
/ Bobcat e35 exc #3
Curious as to what the problem is? My brand new E32 just went back to the shop with the same symptoms.
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A63569)
1994 SHOP MADE...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
40ft Shipping Container (A64194)
40ft Shipping...
Agline ADM110 Hay Mower (A64047)
Agline ADM110 Hay...
John Deere 2155 Tractor W/ Loader (A62613)
John Deere 2155...
