Comparison Bobcat CT450 vs John Deere 4320
   / Bobcat CT450 vs John Deere 4320 #1
OutBurst
Connecticut
John Deere 1026r
Bobcat CT450 on TractorData
John Deere 4320 on TractorData
Spec-wise, looks pretty close. The JD 4320 has a 400CX loader and more 3pt lift (2500lbs vs 1870lbs). However, if the Bobcat CT450 is, essentially, the same as the Kioti DK50SE, why does the DK50SE have more 3pt lift (2493lbs vs 1870lbs)? Rather drastic difference...
The Bobcat has metal fenders, which is always nice, and weighs more by 100lbs.
The John Deere is not 'defunct' so I believe parts will be more readily available through dealerships as well as online.
Thoughts?
   / Bobcat CT450 vs John Deere 4320 #2
While tractordata.com is a great resource, you can't trust their data 100% of the time. I suspect the 3 point lift rating on the Bobcat is wrong. There is no reason whatsoever for the Kioti DK50SE to have over 600 pounds more lift capacity at the 3 point than the Bobcat, which is just a Kioti with a different paint scheme.
I think the CT450 and DK50SE stack up just fine with the 4320, and beat it in certain ways such as loader lift capacity and overall weight. The 4320 has a tiny bit more PTO HP.
   / Bobcat CT450 vs John Deere 4320 #3
I can't say what the future holds, but I get Bobcat parts just as quick as John Deere. Your mileage may vary but repairs happen much quicker at Bobcat as well.
   / Bobcat CT450 vs John Deere 4320 #6
I think they're metal on ROPS versions, fiberglass on cab versions...
2014 FORD E-350 11 PASSENGER VAN (A52472)
2014 FORD E-350 11...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2019 HINO 195 16 FT BOX TRUCK WITH LIFT GATE (A52576)
2019 HINO 195 16...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
