Bobcat CT4045 tractor hydraulic questions
   / Bobcat CT4045 tractor hydraulic questions #1
I just bought a new BobCat CT4045 and I want to run a supply and return hydraulic line to the back of the tractor to run a backhoe. The loader lines from the loader valve to the distribution valve are marked with red, blue, and yellow. I need to know which of the lines are supply and return. I was wondering if the third line was from the relief? The manual is pretty much useless for these tractors except for the tons of safety information they contain. I would buy the single remote but when they told me the price was $850, I think a couple of hoses tied in series with the loader might be a bit less expensive!
Thanks ahead for your help!
   / Bobcat CT4045 tractor hydraulic questions #2
Show a picture of your loader valve.
   / Bobcat CT4045 tractor hydraulic questions #3
It would help your understanding if you got used to using the correct terms as it makes finding info much easier.
Look at the first illustration posted which is of a simple hydraulic valve.
The ports are identified P (for pump) which is the flow from the hydraulic pump, T (for tank) which is the flow to the reservoir from the valve which is from moving cylinders and the relief valve.
A and B are the work ports to a hydraulic cylinder.
Rather than focus on the colors, look for letters cast into the body of the valve.
On a loader valve as you describe, there will be 7 hoses. 4 for the loader arm and bucket cylinders, a P, a T and then the important one for your project.
Power Beyond or in some circles called HPCO for High Pressure Carry Over is the port/line that should be used to feed another hydraulic control valve.
Currently, the PB line is likely used to supply the 3 pt hitch.
Valves typically do not come with PB but rather have provision for an optional plug or sleeve to be installed which then provides the PB feature. See attached illustration.
A T port, possibly a T2 port will have a plug that is removed to allow the PB option to be installed.
Compact loader tractors with a backhoe often have a power beyond loop to supply the hoe.
To get into details of this setup, more info is needed on the valve your backhoe will use.
Dave M7040
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
1999 24DTA pintle hitch trailer (A53472)
1999 24DTA pintle...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
John Deere 310A Loader Backhoe (A52384)
John Deere 310A...
Unused Delta Crash...
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
