Bobcat CT335 Metric Hardware sizes??
/ Bobcat CT335 Metric Hardware sizes?? #1
Trails End
Candia, NH
Bobcat CT335
Up to now, I have used a regular open-end adjustable wrench for maintenance
work on my CT335, but would like to get a set of the most needed metric 6pt sockets,
especially for the larger hardware (loader mounting bracket bolts, wheel nuts and bolts)
but I can't seem to find just what size bolts are used. The parts lists on Bobcat's
web site only list part number, and a title, such as nut, bolt, stud. The service manual
doesn't have this information either, other than the occasional mention of a 15mm
washer on the loader mounting bracket hardware. :confused3:
I'm starting out assuming that all the hardware on the tractor is metric.
Does anyone on the forum have information, (either from experience or otherwise),
as to which sizes are used on the CT335 (or it's Kioti DK35 double)?
/ Bobcat CT335 Metric Hardware sizes?? #2
I have used everything from 10mm up to 22mm. Find a combination set of wrenches and sockets on special and you should be covered.
/ Bobcat CT335 Metric Hardware sizes?? #3
It would be cheaper to by a set than individual tools anyway
I ended up buying a set of Craftsman 1/2" drive 6pt metric sockets sizes 10, 12 thru 15, 17, 19, 21, 22, 24 mm.
That takes care of the oil pan plug, loader frame mounting bolts and rear wheel nuts/bolts. Interesting enough,
I found that the front wheel nuts/bolts appear to require an SAE 1 1/8" socket. It's metric equivalent would be
28.5 mm.
Thanks for all the comments!
