Bobcat CT235 Failing Hydraulic Pump
   / Bobcat CT235 Failing Hydraulic Pump #1
mooseoftoose
Canton, CT
1989 JD 970
I looked at a 2012 CT235 to purchase that is having a problem. It has rear remotes, and one of the levers was left in the detent ON, without anything connected to the remote. As a result, the tractor was run for quite some time (multiple uses) with the hydraulics deadheading, and the pump screaming, relief valve burning, and a steady leaking of fluid out of the lower fitting on the pump. When I looked at it, the owner didn't know about this lever position, so I put the lever back to neutral, and the noise and leak stopped.
I anticipate the pump will need replacing, along with leaking fitting. Does anyone have any idea if the rest of the system could have been damaged from the excessive heat build up? Perhaps all the seals, including the HST unit could be degraded? The machine drove fine, and the loader functioned great, I even lifted a load of rocks no problem. The only reason I am considering buying this gamble is because it is heavily discounted, and very well outfitted with SSQA front bucket, factory heated cab, and factory backhoe.
   / Bobcat CT235 Failing Hydraulic Pump #2
Hydrastat pump and lift pump are separate pumps and systems although they do sharre the same fluid. It should not have had an effect on the hydrastat. If the loader functions without problem I would think the lift pump would be fine. Cannot know for sure but I doubt any major damage has been done. Just an opinion, no fact here. :2cents:
   / Bobcat CT235 Failing Hydraulic Pump #3
The unknown is how hot did the oil get. Agree with winston that if the loader appears to operating properly I would just run it.
   / Bobcat CT235 Failing Hydraulic Pump #4
Check engine oil level make sure it is not over full. If the gear pump has suffered significant damage it will be pushing hydraulic oil out the input shaft seal and filling crankcase with hydraulic fluid.
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
2018 John Deere Z997R (A53317)
2018 John Deere...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
2011 FREIGHTLINER CASCADIA (INOPERABLE) (A55745)
2011 FREIGHTLINER...
2018 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55852)
2018 Chevrolet...
