bobcat CT122 Joystick
   / bobcat CT122 Joystick #1
bjbgjb
Crosslake, MN
Bobcat CT122
loader cannot be raised because of break or disconnect. Cannot access Bobcat parts manual. A schematic would be appreciated
   / bobcat CT122 Joystick #2
What's the history behind this situation? Did it just all of a sudden stop working?
Parts manuals aren't free. Your dealer can order one for you
If it's a break or disconnect there should be a pool of fluid, unless it's a quick disconnect and it should be easy to find.
My tractor has a push-in yellow metal tab that locks the joystick. It's toward the lower end of the joystick facing the front of the tractor
   / bobcat CT122 Joystick #3
Welcome to the forum. :welcome:
I'm going to move your thread on over to the Bobcat section to see if someone over there might be able to help you.
   / bobcat CT122 Joystick #4
   / bobcat CT122 Joystick #5
Loader valve is operated by cable. Valve is under right foot plate. Two places I've seen fail. Cable or gimble.If you roll the lever boot back you can see the set up. If its ok there you may need to remove the assembly to inspect the cables. :thumbsup:
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
23105 (A56859)
23105 (A56859)
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
16001 (A55853)
16001 (A55853)
