3-Point Hitch Bobcat Ct 225 - How to Use the Rear Auxlllary Hydraulic / same time Three-Polnt Hitch
   / Bobcat Ct 225 - How to Use the Rear Auxlllary Hydraulic / same time Three-Polnt Hitch
Exactly
Im guessing the OP has one remote on his tractor which is connected to the snowblowers 2 electric valves which operate the rotator and deflector.
Exactly
   / Bobcat Ct 225 - How to Use the Rear Auxlllary Hydraulic / same time Three-Polnt Hitch #13
He's not going to be able to do that because his rear remote needs to be in detent to use the electrical valves and that constant flow overrides the 3PH. As I said earlier in the thread, I think his best option is to remove the electronic valves and re-hose to either a) just control the rotation of the chute with his detent remote where it is never left in the detent position b) obtain dual remotes and re-hose to control both chute rotation and elevation, or c) the suggestion of "a" and acquire an electrically controlled 12V linear actuator for the chutes elevation from Princess Auto (similar to Harbor Freight in the ) since he already has an electricity supply to the unit.
   / Bobcat Ct 225 - How to Use the Rear Auxlllary Hydraulic / same time Three-Polnt Hitch #14
I'm sorry, I didn't see that it would be apparent that only one function occurs at the snowblower and it is to rotate the chute, but no chute elevation.
You will need to remove the electrical control valve from the hydraulic circuit and run your hoses directly to the hydraulic motor on the chute. Then utilize the rear remote lever to control it.
Ok thx
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A55745)
2017 TROXEL 130...
23110 (A53424)
23110 (A53424)
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
2009 MULTIQUIP 25KW GENERATOR (A53843)
2009 MULTIQUIP...
