Bobcat CT 225 engine oil question?
   / Bobcat CT 225 engine oil question? #1
BobcatTR
Decatur, IL.
Bobcat CT225
Hi guys, oil change time, what do you use?
15-40, 5w-20, 5w-40 synthetic, or standard.
I use synthetic, in my cars.
Live in Illinois, so not real bad weather.
Thanks for your input!
Terry
   / Bobcat CT 225 engine oil question? #2
I use Rotella 15w40 but don't believe it is the only thing out there. Just had good success with it so keeping on keeping on.
Thanks Winston1!
Is that a synthetic?
I work at a municipality, maintenance uses standard 15-40, on all our diesels.
I just want the best to keep her running as long as I can! As we all do.
   / Bobcat CT 225 engine oil question? #4
If you want synthetic, Rotella t6 5w40. It's what I use. The 15w40 is either synthetic blend or conventional. Can't remember.
Thank you! I checked Farm&Fleet synthetic Rotella is worth it! Thank you!
   / Bobcat CT 225 engine oil question? #6
I am sure the synthetic oils are a notch or two better than the conventional but at 72 years old I have never experienced an engine failure using the old stuff. I think the key is proper oil and filter changing intervals.
+1 on that Winston!
Been changing oil for dad since I was knee high! Lol.
Correct intervals is a must.
Still have a hard time with 5000 mile changes.
So used to 3000.
Plus they skip filters every other time.
Still have a hard time with that!
   / Bobcat CT 225 engine oil question? #9
sorry for my delay . The oil is characterized with classification except viscosity ,for Bobcat the engine oil is specific API CL-4 and ACEA E7
2019 POLARIS RANGER 4x4 UTV (A51222)
2019 POLARIS...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
2020 KUBOTA RTV...
1994 Toyota 6000lbs 2 Stage Forklift (A51039)
1994 Toyota...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
