bobcat ct 122 loader bucket
   / bobcat ct 122 loader bucket #1
mike 1010
las vegas nm
bobcat ct 122
I have a bobcat ct 122 loader lifts fine and will dump and curl back up. My problem is that the loader arms will not come down once they are up. If I float the bucket it will start to creep down until it hits the ground. Also when I try to lower arms it logs motor as if it is straining under pressure. I have checked fluid and bled the hydro lines and no help, any ideas would be welcome. thanks
   / bobcat ct 122 loader bucket #2
If you can take the pressure off, by opening a fitting, let the loader down then check you quick couplers with engine off.
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2007 International 4300 Dump Truck (A51692)
2007 International...
2017 Chevrolet Tahoe SUV (A52377)
2017 Chevrolet...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
John Deere 73 Inch Materials Bucket - Needs Carrier (A55218)
John Deere 73 Inch...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
