BOBCAT CT 122 Hydraulic problem?
   / BOBCAT CT 122 Hydraulic problem? #1
hypogee
New York
Bobcat ct122
I have a 2009 Bobcat CT122 with 139 hours on it. I'm having an issue where The loader lifts/dumps/etc extremely slow empty and not at all with any load. Also having hesitation with the rear arms lifting and no downward pressure. I've let the tractor and oil warm up, well over an hour and no change, with rpm maxed when in use. All oil levels are full and all connections have been cleaned and checked for leaks. I bought this unit used and being not too familiar with Bobcat I'm looking for any help. Thanks for your time!!
   / BOBCAT CT 122 Hydraulic problem? #2
First thing I would do is check the hyd pressure to see if the pump and components can develop the advertised pressure.
If you can't develop the pressure, you have to find the cause.
Maybe pump, cyl seals, relief valve, etc.
   / BOBCAT CT 122 Hydraulic problem? #3
The 3 point hitch arms have no down pressure. They power up and gravity down only.
   / BOBCAT CT 122 Hydraulic problem? #4
could be a pump. Remember that tractor is a Kioti so you can go through a Kioti dealer.
   / BOBCAT CT 122 Hydraulic problem? #5
The Dk35 doen't have down pressure or in fact does any other of the Kiotis on the 3 point.
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2015 FREIGHTLINER...
(APPROX 15) 2" X 6" X 68" TUBING (A54756)
(APPROX 15) 2" X...
2016 FREIGHTLINER CASCADIA (A53843)
2016 FREIGHTLINER...
2008 BMW 535xi AWD Sedan (A53424)
2008 BMW 535xi AWD...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
