Bobcat B250 problem with "push to drive" button
/ Bobcat B250 problem with "push to drive" button #1
manaroundthehouse
I own a 2005 Bobcat backhoe B250. Everytime I push the "push to drive" button, it blows a fuse. When I try a bigger fuse, I seem to smell something burning, as if the wires are getting hot. Anyone have any ideas on this? Much appreciated.
John
/ Bobcat B250 problem with "push to drive" button #2
You have a short some where and putting a larger fuse in will cause something else....like you whole wiring harness to burn/melt. New fuse $.50..new wiring harness $$$$$. Take it to the dealer so they can track down the short.
/ Bobcat B250 problem with "push to drive" button #3
Hope you don't mind me cutting into this thread, but I have a question specifically about your b250--How well does the backhoe dig? Would you think it would be able to dig out a foundation for a garage/addition? Stumps?
Thanks,
Aaron
/ Bobcat B250 problem with "push to drive" button #4
Manaroundthehouse,
Saw your post in the construction area. I have an Earthforce EF3. Its basically a Bobcat B200 with Four Wheel Steer and a different loader up front. Hydraulics are the same as far as I can tell.
Agree with earlier answer - you probably have a short. Take the dashboard off (just the cap) and see if some of the contacts are touching others or the steel dash - its pretty cramped in there.
BTW, my green Push-to-Drive button failed intermittently. I traced it to a bad solenoid, the solenoid/relay to the far right in the top picture posted by Westcliffe01 in the other post (Construction Post). But I couldn't fix it (don't know how).
I took to my bobcat dealer, who is real understanding about these machines. He thought it was the green switch, though I thought I had already ruled that out. Well he figured out it was the green switch and bypassed it with another momentary switch. Works like a champ.
2012 Ford F-150 Pickup Truck (A64194)
2012 Ford F-150...
Barrel (A64557)
Barrel (A64557)
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2017 Isuzu NPR-HD 14ft. Stakebody Flatbed Truck (A64556)
2017 Isuzu NPR-HD...
2015 Ford Transit 250 Cargo Van (A64556)
2015 Ford Transit...
2012 Peterbilt 337 S/A 17ft. Cab and Chassis Truck (A64194)
2012 Peterbilt 337...
