Bobcat B250 problem with "push to drive" button
   / Bobcat B250 problem with "push to drive" button #1
manaroundthehouse
I own a 2005 Bobcat backhoe B250. Everytime I push the "push to drive" button, it blows a fuse. When I try a bigger fuse, I seem to smell something burning, as if the wires are getting hot. Anyone have any ideas on this? Much appreciated.
John
   / Bobcat B250 problem with "push to drive" button #2
You have a short some where and putting a larger fuse in will cause something else....like you whole wiring harness to burn/melt. New fuse $.50..new wiring harness $$$$$. Take it to the dealer so they can track down the short.
   / Bobcat B250 problem with "push to drive" button #3
Hope you don't mind me cutting into this thread, but I have a question specifically about your b250--How well does the backhoe dig? Would you think it would be able to dig out a foundation for a garage/addition? Stumps?
Thanks,
Aaron
   / Bobcat B250 problem with "push to drive" button #4
Manaroundthehouse,
Saw your post in the construction area. I have an Earthforce EF3. Its basically a Bobcat B200 with Four Wheel Steer and a different loader up front. Hydraulics are the same as far as I can tell.
Agree with earlier answer - you probably have a short. Take the dashboard off (just the cap) and see if some of the contacts are touching others or the steel dash - its pretty cramped in there.
BTW, my green Push-to-Drive button failed intermittently. I traced it to a bad solenoid, the solenoid/relay to the far right in the top picture posted by Westcliffe01 in the other post (Construction Post). But I couldn't fix it (don't know how).
I took to my bobcat dealer, who is real understanding about these machines. He thought it was the green switch, though I thought I had already ruled that out. Well he figured out it was the green switch and bypassed it with another momentary switch. Works like a champ.
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A52748)
NEW 2024 LOAD...
2014 Ford Fusion Sedan (A50324)
2014 Ford Fusion...
JLG 1055 (A50120)
JLG 1055 (A50120)
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
18' Utility Trailer with Gate (A50121)
18' Utility...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
