Bobcat B200 won't go
   / Bobcat B200 won't go #1
Doof
Bobcat B200
New to the forum so Hello I have inherited a Bobcat B200 tractor that stopped and sat for 8 yrs. The implements work so the gear pump is working. The research I have done shows that this was running problem with this tractor. Haven't been able to find parts and if I find a pump it will be over $3000. Does anyone have experience or knowledge of a third party pump or retrofitted another manufacturer's pump to this tractor. One dealer just said "good luck". Hate to by the original pump just for it to fail again. Thanks for reading
   / Bobcat B200 won't go #2
Well, got a quote from a reputable hydro co. in New Hampshire. They found the parts in Europe with a 3 to 6 month lead time and $5000 for a rebuild and $7000 for new. The tractor is worth about 10,000 fixed and also needs new rubber. So now is it worth fixing or should I part it out. Everything else works and it is a nice hoe and bucket. Still hoping someone out there has a less costly answer even if I have to do some plumbing or any way to put a manual tranny in. Maybe by an old tractor and fit the hoe and bucket to that Any views on the idea? Thanks for listening.
   / Bobcat B200 won't go #4
Could you pull the pump and find out what broke? You may be able to fix it yourself.
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
PARTS ONLY - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - 2023...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2003 Big Tex 10PI...
