Bobcat B200 won't go
   / Bobcat B200 won't go #1
Doof
Bobcat B200
New to the forum so Hello I have inherited a Bobcat B200 tractor that stopped and sat for 8 yrs. The implements work so the gear pump is working. The research I have done shows that this was running problem with this tractor. Haven't been able to find parts and if I find a pump it will be over $3000. Does anyone have experience or knowledge of a third party pump or retrofitted another manufacturer's pump to this tractor. One dealer just said "good luck". Hate to by the original pump just for it to fail again. Thanks for reading
   / Bobcat B200 won't go #2
Well, got a quote from a reputable hydro co. in New Hampshire. They found the parts in Europe with a 3 to 6 month lead time and $5000 for a rebuild and $7000 for new. The tractor is worth about 10,000 fixed and also needs new rubber. So now is it worth fixing or should I part it out. Everything else works and it is a nice hoe and bucket. Still hoping someone out there has a less costly answer even if I have to do some plumbing or any way to put a manual tranny in. Maybe by an old tractor and fit the hoe and bucket to that Any views on the idea? Thanks for listening.
   / Bobcat B200 won't go #4
Could you pull the pump and find out what broke? You may be able to fix it yourself.
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
2006 Volvo VNL (A51039)
2006 Volvo VNL...
TOYOTA 7FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 7FGCU25 LP...
2022 Club Car...
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
