Loader Bobcat 943 Hydraulics operate in only one direction
   / Bobcat 943 Hydraulics operate in only one direction #1
Robertsroost
Inyokern, Ca
Bobcat 943
Bobcat 943 Hydraulics operates in only one direction, I accidentally ran the system low on fluid and now the arm will now only go up and the bucket will only tilt down in one direction.
I have cycled the system by raising and then shutting the engine down and cycling the pedal until the bucket comes back down under its own weight. I also have bled the system by cracking lines at the the cylinders. Need your help.
Thanx!:)
   / Bobcat 943 Hydraulics operate in only one direction #2
You will get a better chance of an answer if you post in the Bobcat - Construction Equipment section of the forum.
We own, operate and talk about the Bobcat agricultural tractors here.
