bobcat 873 won't start
   / bobcat 873 won't start #1
bcantell
Brimfield, MA
Bobcat 873, Mini Volvo EC25, SkyTrac 7038
My 873 won't start. The lights and dials all just blink when I turn the key all the way. No codes when I hold the light button down for two seconds. I can hear a "click" in the back and then the blinking starts without any red lights on the panel showing. Battery is newer, about 2 years. Any ideas?? Thanks. Bill
   / bobcat 873 won't start #2
I think you answered your own question. Get the battery checked out. I learned something over on the FTE Forum (Ford Trucks). A guy always said, KISS, meaning, Keep It Simple Stupid.
I use that philosophy often.
   / bobcat 873 won't start #3
First check battery then alternator. If it don't charge it won't start......
Thanks for the help. I don't understand why but the problem seems to be rear light. It had fallen out and was lying inside the back door still attached by the wires.. I couldn't find any short or stripped wire. I put it back in and she started right up. ???
   / bobcat 873 won't start #5
Most likely not related. I'd keep checking. If the light did the trick then there is still a problem as the charge current is not going where it is suppose to.
   / bobcat 873 won't start #6
Hi from Afghanistan,
I own the 873. Over the summer mine would intermittently make a single click but the engine would not turn over. I fixed the problem by taking the starter motor off and cleaning the solenoid. Mine had dirt in it which mucked up the contacts. Bob
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2017 DODGE RAM 5500 HEAVY DUTY SERVICE TRUCK (A51243)
2017 DODGE RAM...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
