bobcat 843 no lift or curl control
   / bobcat 843 no lift or curl control #1
laurencen
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
used the bobcat 843 to move snow for 3 hours yesterday, no issues, today started fine but no lift, lower curl up down on the bucket, it drives as usual but if you lift the arms they go up half inch and stop, try to lower arms and again goes up half inch ans stops, push the right pedal either way the bucket will move down slightly and stop
there is no noise from hydraulics if you hold the pedal in any position, too late today to look under the cab, anyone have a idea what may be the cause, thanks
   / bobcat 843 no lift or curl control #2
Have you checked hydraulic oil level?
oil level is good and clean, thinking about it hard starting had to put charger on it, now im thinking my son may have pushed the lever for the auxiliary, have to check that in the morning, would this cause the symptoms?
   / bobcat 843 no lift or curl control #4
Front auxiliary is locked ON. Pull the Right drive lever sharply to the left to unlock
   / bobcat 843 no lift or curl control #5
I was going to suggest the same thing. Other wise you need to get a pressure gauge and see if your pump is good.
thanks guys, it was the right lever, must be getting old thee days and feeling a little dumb, this machine is one for around the works for snow and a bit of driveway gravel, must admit Im getting lazy for the last 4 years using the S590 with joystick controls, anyway its back running like it always has
   / bobcat 843 no lift or curl control #7
New Holland 781 has a similar lock setup and it for no reason at all just locks. ---its annoying as heck when your in a hurry!
   / bobcat 843 no lift or curl control #8
It is not a lock. It actuates the aux ports, but one direction has detent so it stays in that position for running motors or such on the aux ports. But if you don't have anything hooked up to the aux ports, it maxes out the hyd pump against the relief and you get no pressure to the other controls. Happened to me a few times when I first got my 843. Now I know to check it when it doesn't seem right.
and the mystery evolves, my grandson was in it the night before, he likely moved every lever and switch that can move, my son figures its funny I could not figure it out, well I had no idea a 6 year old was playing in it
1986 Peterbilt 359 Truck, VIN # 1XP9D29X9GD196948 (A51572)
1986 Peterbilt 359...
40FT Shipping Container (Modified for Parts Storage) (A51573)
40FT Shipping...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
2018 John Deere 8400R MFWD Tractor (A53342)
2018 John Deere...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
Deere 9970 Cotton Picker (A53472)
Deere 9970 Cotton...
