bobcat 825 planetary unit
   / bobcat 825 planetary unit #1
bc825er
bobcat 825
just bought a 1977ish bobcat 825 skid steer, mechanic states it needs a planetary unit, right side, but having trouble finding one at a reasonable price. any suggestions
   / bobcat 825 planetary unit #2
It wont be cheap, for some reason there is not alot of skid steers junked out. If your able to find what you need used it will certainly be cheaper than new but your gonna hafta ante up in most cases. I had to replace both gear reduction units on an early 80's 843 a couple years ago IIRC $600 per side, used parts then had to reseal them before I used them.
thanks, So far I ve found one for $950 used, still looking, i was hoping to find one in $600 range, I purchased the 825 for $3500 which owner thought it just needed axle seal replaced, if I can get repaired for $1500 I think I ll have a good machine to clean up around my property.
   / bobcat 825 planetary unit #4
Are you sure it just doesn't need bearings and seals? Do you have it out? Make sure it's not simple before you start throwing $$$ at it.
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
City of Lakeland (A51691)
City of Lakeland...
