Bobcat 773 hot lead for lighting
   / Bobcat 773 hot lead for lighting #1
elginfarm
Southwest suburb of Chicago Area
JD 4400
Hello Members,
I have a Bobcat 773 that I would like to add some auxiliary lights and a USB outlet to my machine. Where can I find a hot lead controlled by the ignition switch? I would add an auxiliary fuse box fed through a relay from the battery and use the fuse box for my feeds to the light switches.
Any information or suggestions would be greatly appreciated.
Thanks in advance.
   / Bobcat 773 hot lead for lighting #2
if you locate the relay in the engine compartment I would look for a hot when ignition turned on possible the fuel cutoff solenoid would be my choice
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
91013 (A48082)
91013 (A48082)
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
2015 Ford F-450 Service Truck, VIN # 1FDUF4GT7FEC15731 (A51572)
2015 Ford F-450...
