Bobcat 773 hot lead for lighting
   / Bobcat 773 hot lead for lighting #1
elginfarm
Bronze Member
Southwest suburb of Chicago Area
JD 4400
Hello Members,
I have a Bobcat 773 that I would like to add some auxiliary lights and a USB outlet to my machine. Where can I find a hot lead controlled by the ignition switch? I would add an auxiliary fuse box fed through a relay from the battery and use the fuse box for my feeds to the light switches.
Any information or suggestions would be greatly appreciated.
Thanks in advance.
   / Bobcat 773 hot lead for lighting #2
if you locate the relay in the engine compartment I would look for a hot when ignition turned on possible the fuel cutoff solenoid would be my choice
New 3pt Sod Cutter (A50774)
New 3pt Sod Cutter...
Kubota GR2120 (A47384)
(10) IH Suitcase Weights (A50515)
(10) IH Suitcase...
Wolverine Quick Attach Screening Bucket (A50514)
Wolverine Quick...
1985 Big D Pintle Hitch Trailer (A50514)
1985 Big D Pintle...
